I've recently fitted a bath as part of a renovation. Existing piping is 15mm (hot comes from modern Combi in loft). I just used 15mm to 3/4 braided hose with an isolating valve. However I've since looked at the spec of the hoses, and the bore is about 10mm. This will surely reduce flow to the bath taps?
Not sure what to replace them with, as I want to be able to isolate them with full bore valves but don't want to then reduce the bore with flexi hoses, or plastic pipes with inserts at the fitting..all I can think if is to use a reducer and copper pipe right to the taps, but not 100% confident I'll be able to line it up spot on.
Any ideas?
Any ideas?
