15mm flo fit pipe to 25mm MDPE pipe. HOW?
23 Dec 2006
Merseyside
Looking to tap into a 15mm cold water feed with 25mm MDPE pipe to run to out door koi pond. Read on the forums a wider pipe ie 25mm would allow better pressure hence the size difference.
Its probably really obvious but what connection would i use? i`ve seen copper to MDPE tee connectors, would flo fit push connectors do the job or am i looking at ALOT of joints/reducers to get the connection.
Can't really see any benefit in running 25mm, 20mm poly should do and you can easily get 15 - 20 mm couplings.
It would make very little difference to the pressure using 25mm or 20mm pipe, you would have a slightly better flow rate using 25mm but don't think the fish would be that bothered.
Cheers for the replies, fastest customer service i`ve ever known.
I`ll return the 25mm and get 20mm and some connectors.
Keep it simple stupid! :rolleyes:
