Hi all ,
I'm planning on installing 2 radiators in my living room/dining room. I noticed after lifting the floorboards that the CH pipes are 15mm the whole way. I'm lifting as little as I can as it will cause too much disruption otherwise, but I'm guessing it's the same everywhere in the house.
The pipework coming off the boiler are all 15mm.
My question is whether I will get enough flow to the 2 new radiators as they will be a reasonably long run/end of run. The boiler can handle the btu as we only have 3 single panel radiators in the house and its 25kw. But I worry the rads may not get warm enough. Oh and they're both vertical rads just to make the issue more fun!
Any thoughts will be appreciated. Thanks
