I need to remove a plastic compression fitting from the water feed pipe to the ensuite toilet. The compression fitting is attached to a copper pipe that connects into the bottom of the toilet via a valve. I ultimately want to replace the copper pipe with a flexible hose.
Thanks in advance for any help.
