My kitchen with a concrete floor is proving to be a pain in the ass as I want to fit a radiator in there however it will only fit on one small wall. I have decided that I would rather not rip up the laminate and chase out concrete so i took off the skirting and chased a chanel in behind it to see what depth there was to the brick wall. see pics:
http://i252.photobucket.com/albums/hh22/pippo777/DSC01093.jpg
http://i252.photobucket.com/albums/hh22/pippo777/DSC01094.jpg
My plan was to run the barrier pipes in here from the boiler cupboard on the right, then use 90 elbows behind the skirting, drill 15mm holes in the skirting and insert copper thru the skirting and into the elbows. with soldered 90's or 90 bends taking the copper up into the radiator above. Would the heat from the pipes cause problems? Would it be hot enough to scald the skirting, movement etc?
thanks for any advice or any other ideas.
pippo
pippo
