Hi guys, I recently ripped an old tap out in a friend’s new restaurant as it was old and wobbly.
Anyway, the tap was connected via 2 copper tails in to generic connectors and then into some plastic 15mm pipe running to the mains.
There were no inserts used (it’s been there about 20 years I believe).
I want to use SpeedFit. I plan to get a new tap and some SpeedFit tap hoses with some SpeedFit in-line connectors and some SpeedFit inserts.
My questions is, is it ok to use the SpeedFit inserts and in-line connectors on the non SpeedFit 15mm pipe that’s already there?
I want to use the connectors to extend the pipe a bit as the distance between the pipe and tap is exactly 300mm and it’s very tight.
Thanks.
Thanks.
