15mm stop tap between 25mm mdpe and 22mm copper
31 May 2007
Hello everyone
Quick question
In between 25mm mdpe and 22mm copper is a 15mm stop tap, 15mm copper has been fitted for about 10cm either side to create the connection.
I have an unvented mains pressured system, do you guys think this 15mm bottle neck has any effect? Is it worthwhile fitting a 22mm stop tap in terms of output?
Many thanks
Thanks for your reply
Lever valves appear to be cheaper to.
Many thanks
Just like my sister.
28mm plastic pipe to the 3 bathroom property.
Then 15mm stop tap!!!
Did the builder ever engage brain??
I'm siting back until they move in and waiting for the call.
You need a FULL bore level valve.
Full bore lever bought, push fit mdpe to 22mm reducer, thought I had 22mm pipe when I pulled it out was 28 arghh! Back to the merchants tmrw.
Cheers
