Hi, I have a 16 amp mcb on my distribution board, which is currently only being used to power my combi boiler (3 amp fused connection unit) located in what is to become my utility room, no ring main for sockets is present. I would like to tap into the cable running to the fcu with a junction box and run two double sockets off it, one to provde power for a washing machine and tumble dryer and the other to be a spare for using an iron etc. My question is this - is the 16 amp mcb enough to support this load or should it be upgraded? Also the mcb is on the main switch side of my consumer board i.e not the rcd side, is this a problem?
