First of all I will get an electrician to fit the new consumer unit. This post is about running a cable while I can still get to it easily.
The current setup:
Consumer unit downstairs feeds an 80amp fuse ( right next to downstairs cu) which feeds an upstairs consumer unit about 15meters away using 16mm twin and earth cable. Its definitley 16mm on the live and neutral, I have used a micrometer on the individual strands and checked, however the earth seems thinner.
If I need to change the cable, I need to run it now because of the stage I am at during a renovation. I don't intend to connect it yet just have it in place ready.
The upstairs cu will have 2 electric showers, an electric oven, hob, dishwasher, a couple of electric hand washes, 2 ring circuits, and lighting. (no gas).
My question (or questions) is:
Do I need to upgrade the cable from 16mm to 25mm or is 16mm fine?
Will an 80amp fuse be sufficient for the said load?
Does there need to be a separate earth running with whichever cable I use or is the current set up of twin and earth correct?
For obvious reasons, I have not touched the cable that on the side of the first consumer unit/meter side of the fuse, but at a glance that looks to be 16mm too. I am asuming that would need to be upgraded too if I were to change the other to 25mm?
Thanks in advance for anyone that can give me a definite answer to one or even all of the questions and I'll just re-iterate I will not be making the final connections, I just want to run the cable (if I have to) before I reach a point where I cant get under the part of floor where I intend to run it.
The cable runs under floor boards and then in a hollow stud wall vertically up to the current consumer unit so its in the safe zone.
The current setup:
