I've now fitted a new pump and diverter valve (both confirmed as faulty) to this boiler - a VCW GB 221H. The DHW is fine, but the CH is still problematic.
To get the CH to start, the boiler has to be switched off, drained, have at least one of the banjo pipes at the bottom disconnected, refilled and then switched on. This will start it 99 times out of 100 (Yes, I've done it that often!). However, the CH will then run for an amount of time ranging between 30 mins to several hours.
Should I just accept that 17 years is a pretty good run and replace it, or is there life in the old dog yet?
Cheers,
Heggsy
Cheers,
Heggsy
