I have a 16th Century timber framed house. It has been previously rendered with a cement render, onto expanded metal lath attached directly to the frame.
Clearly, a timber frame ought to be ventilated, and this cement render does not allow the frame to breathe. Moreover, where the cement has cracked, this has been letting water in and not letting it evaporate back out, causing local rot, which I have now cut out.
I am loathe to remove the render throughout, as it is offering considerable structural support to the frame. But I am looking for a way of allowing an air flow around the frame. I am wondering whether I could, for example, drill lots of holes in the render, counter batten and re-render over the top in lime. Or have airbricks or vents in the outer render. Would I use a breathable membrane? In which case where?
Does anybody have any expertise in the area of old buildings, and can anyone advise on how I could allow a timber framed house to breathe, through the cement render, and allow an air flow around the frame?
Many thanks
Many thanks
