Have a friend who is embarking on the 17th edition course we wa t to know what the pass mark is? And any online test questions ?
60% or 65% {.....} It's an open book test
Indeed it would, but (at least in terms of pass mark - not the 'open book' bit!) it's far from unique to electricians. Those whose primary qualifications are university degrees, including those practising in the major professions (medicine, law, teaching etc.) will often be 'qualified' on the basis of exams with an overall pass mark not a lot over 50%, sometimes even as low as 40% or 45% ... so, theoretically, some of them could know less than half of what they would ideally know! That's why, in almost any walk of life, one has to look beyond paper qualifications to get any useful measure of 'competence'!That would explain a lot.60% or 65% {.....} It's an open book test
Indeed. I was rather prompted to make my comment last night after having just read a question posted on another forum about a light-switching problem. It was clearly the once-common arrangement of 2-way switching for the upstairs landing light, with a 2-gang switch in the lower hallway to control the downstairs hall light as well, a 2-core red/black switch loop to each switch position for up & down, plus a 3-core red/white/blue running between the two switch positions to provide the 2-way switch link for the upstairs lights. The description of the wiring at the upstairs switch indicated "conventional" method as opposed to "conversion" method of wiring, but it seems that somebody had swapped around a couple of the conductors at the downstairs 2-way.That's why, in almost any walk of life, one has to look beyond paper qualifications to get any useful measure of 'competence'!
It's something I am (and will continue to be) proud to be criticised for saying!Well - good luck with promoting the idea that people should actually understand what they are doing, no matter who they are, and no matter what the work is, rather than just blindly following instructions to put this wire into that hole. Expect to get used to being regularly criticised for it.
I do that as little as I can - and, when I do it, it's only because I feel that, in the particular situation, it is probably the least of the available evils - but it most certainly does not mean that I don't believe that anyone doing anything should have a full understanding of the underlying principles - which is far more important than 'chapter and verse knowledge'. My personal view is that their true understanding of the underlying principles is far more important than their understanding of word of the regulations or their compliance (or otherwise) with such things as notification to LABCs. You have only got to look at the level of understanding of basic principles of some of those who are allowed to self-certify to see the lunacy of the situation we currently have.Don't make me laugh. You regularly tell people how to do things, knowing that they don't genuinely understand, on the grounds that if you don't they'll blunder ahead anyway, and just as regularly criticise me for taking the stand that if they don't understand it they need to either go off and learn until they do or get an electrician.
