Looking through the 17th edition there is a requirement to protect cables such as twin and earth which are buried less than 50mm from the surface with a 30mA RCD.
RCD protecting the whole installation is a bad idea as a single fault will cause all the lights to go out.
This leaves a some options, installing a dual RCD board with main isolator (I think hager make them) spreading the lighting circuits and socket circuits between the two RCDs, or installing a normal split load board with the sockets etc on the RCD side, utilising RCBOs for the non RCD side for items such as lights (6A RCBOs not being the most readily available part yet.)
Whats everyone elses take on this?
