Chaps
Have a 1930s house. ground floors are void / air brick with joists then floorboards. Drafty and chilly in winter. We want to retain the floorboard look. I've been round and insulated as best I could between boards etc but realistically, it is time to pull the boards up and sort things out properly.
Am thinking battens onto joists, then 50mm celotex between each joist, followed by either expanding foam or tape round the joints to eliminate most (ideally all) of the air gaps then re-lay either the existing or a new floor.
My question is, if I do the above, would I also be able to lay some underfloor heating pipes and then screed over the celotex up to the level of the joists?
Ta muchly.
Ta muchly.
