I've recently moved into a new house with an alarm system that although in the past apparently worked, currently does not. Looking inside I noticed one of the 20x5mm 1A glass fuses has blown. I wanted to replace this to see if this would cure the problem. Looking around I notice you can buy both fast or slow blow fuses. Is there any way I can get this information off the old fuse or does anyone know which sort to use?
