1st floor extension on existing extension - footings
17 Jan 2012
Hertfordshire
hi all first post so be gentle :D
i have full planning for a 1st floor extension on an existing extension the building inspector wants to view my footings
i have just finnished digging out an inspection hole and found the footing is 1 metre deep from ground level 600 concrete and 400 brick
is this going to be enough ?
thanks in advance ;)
dan..
Who knows.. work out the loading that will be applied to the footings area when your new extension is on there and then work out the allowable bearing pressure of the soil with all factors of safety and compare the two..
Chances are, unless you have poor quality ground that a 600wd footing will be ok..
edit.. hold on do you mean 600 deep concrete or wide.. cos depth of footing is a little irrelevant width is key
An existing extension with 1m deep foundations is most likely to be ok for a second story
