Singles.Bettter because its easier to pull through
Why conduit?25mm round pvc conduit surface mounted
Plastic?Six double sockets on ring main
I live in england
When you applied for Building Regulations approval what did you say would be the way you would comply with Part P?...New Garage
Is that an obstacle, or an answer to your question?Singles.Bettter because its easier to pull through
Knowing why you want conduit would help us give the best advice, which might be to not use conduit at all.Why conduit?25mm round pvc conduit surface mounted
Knowing the type of sockets along with the reason for conduit in the first place would help us advise on whether you've chosen the right sort, and also to look at how you're going to terminate 25mm PVC conduit into the accessory enclosures.Plastic?Six double sockets on ring main
1) A ring may not be the most appropriate design.Why a ring?
If you, by default or by unthinkingly copying the standard text from your LABCs website said that the electrics would be done by a registered electrician then the answer toWhen you applied for Building Regulations approval what did you say would be the way you would comply with Part P?
Six double sockets on ring main + 2 lighting circuits
I live in england
