I have a WB 28cdi rsf to which i intend connecting a room stat. WB stipulate a 3 wire stat for this boiler. I've noticed the majority of digital stats are 2 wire connections, my question is can i fit a two wire stat and if so which wires do i connect into the 3 wire terminal and if i make a mistake with these two wires what are the likely consequences?
What is the difference (apart from the obvious) between two and three wire stats?
