C
calumr135
hi there guys. I have just won an elmdene prima 200 on ebay which I am going to install on my parents house along with a texecom oddysey 3.
I plan to install the prima at the front and the oddysey at the back. I will use the oddy as SCB.
I understand the wiring set up for 2 bellboxes. but i have a couple of questions.
1: as the bellboxes are different will there be any issues with tamper?. I read somewhere that some bellboxes have a current limit resistor on the tamper return. which may prevent the second bellbox working properly.
2: I believe the oddysey has an issue with backfeeding voltage down the trigger wire will this effect the first unit in any way (chirping)?. if so could you recommend a 12v diode which I could use in line with the trigger wire going to the first unit.
from your experience will 2 different bellboxes work fine together or will I have the above problems.
system is a scanny 9600 and both bells have their own cable back to the panel. thanks
