Right we bought a house and everything with the central heating was semi ok. We were decorating and noticed that pretty much every radiator was leaking, so we changed all the valves on all the radiators. While all the rads were off the walls, we thought why not flush them out. When we did big fat lumps of muck came out. Before we touched these, all rads got hot.
Now that may have nothing to do with anything, but thought I would put that anyway.
Now, the heating up stairs is fine, boiling in fact. Heating downstairs is non existant. If we turn off all the rads upstairs, the downstairs ones get hot, but only the tops of them. Now I thought ok, maybe its some of the sludge and other crap that we saw before and that it had got moved round the system downstairs and is blocking the radiators and maybe the pump can't move it back up. However I took both rads downstairs off again today and flushed them again and nothing really came out.
Put them back on the walls and filled everything up (bled everything and removed all air pockets, at least I think) and again the rads upstairs are boiling and the rads downstairs are cold.
The pump, a Grundfos 15/50, appears to be working away quite happily. Its spinning like crazy anyway. Its currently set to 2 however I had it on 3 and it made no difference. So for noise sake as it made no difference either way I put it on 2 again.
Motorised valve appears to be working. This is a Honeywell V4073.
The boiler is a Potterton Flamingo 50, bit old but is doing a great job. Its on its lowest setting and heats the water and upstairs rads in no time at all. It gurgles a little now and then, but overall it is heating things so that appears to be working.
The heating as far as I can tell is a Y plan system although this is a best guess.
Hot water is fine.
Central heating thermostat is downstairs so its surrounded by cold and is making the boiler fire pretty much constantly.
Ideas?
Hot water is fine.
Ideas?
