We have 1 luke warm and one cold rad in hall and living room. It started last year and have put up with it but trying to solve. Put desludger into system for a week plus and then drained and flushed system thoroughly. Refilled and not solved.
Drained again, took radiators off, flushed thoroughly lots black stuff came out even though water had run clear on draining whole system. Put back, no change. Shut down all radiators but these 2 and still no change.
Can feel hot water in pipe to hall rad but not as hot as other rads. Cold rad pipe entry feels luke warm. Advised to change pump. Did so and this had no effect either. When we drained system one of the times we did it out of one of the bad radiators and it drew hot water through both rads.
The pin on the trvs are going up and down fine. Boiler gas Stelrad/Ideal Mexico. Nothing changed before it started happening. We've done a fair bit of plumbing before but are so out of ideas, help!!
