Hi All
I have 4mm two core SWA between my consumer unit in the house and a second in the garage, which incidentally is connected to the house. It runs in a concrete floor and would not be easily replaced.
I am currently re-wiring the house and have changed the consumer unit to a split way MK unit. Much better than my old 4 way re-wireable unit. Before anybody asks, i am aware it comes under Part P etc and have already informed building control.
My question is this, I have terminated with the correct gland (after much frustration) into a metal box and am then going to run in 4mm T&E to the MCB in the consumer unit connecting the two cables via 32amp choc blok. The cpc from the T&E continues through a hole in the box and then bolted to the banjo. Is this ok?
Secondly the SWA is in old colours. Can a tape the old cables or use heatshrink to keep the harmonised colouring that runs through the rest of the house? I did have a copy of the on site guide and regs from my mate but he has had to have them back so i can't reference them.
Sorry for the long explanation but i know you guys like plenty of information.
Cheers
Cheers
