Hi
Hope I’ve put this in the correct forum.
I’ve a 4m x 4m Internal concrete floor, its years old but in good condition. I’m going to be laying a laminate floor over it.
I’m going to be putting down a dpm with 75mm of ecotherm for insulation.
My question is should I lay a second dpm on top of the ecotherm before I lay the thin laminate insulation and then the laminate?
My thinking was in case of spillages as the room is going to be a man cave or will I have a problem with moisture getting trapped between both dpms and maybe forming mould.
Im leaning against only using bottom dpm but wanted confirmation.
Thankyou
Thankyou
