2 foul pipes crossing one another
24 Mar 2008
Hi there
Is it ok to have two foul pipes crossing through each other (one from a WC, one from a sink/ bathroom) in a kind of cross roads situation with a manhole at either end rather than where they meet? If so where can I find the pipework capable of this?
I can not imagine a cross roads type situation!
You would feed one into the other making the second part of the cross road redundant. If the pipe run is taking solid waste then it is likely you will need an inspection chamber, at this junction.
