hi
I am installing a pond filter and garden lights, I want to install a 2 gang one way switch to operate both filter and lights. I have used armoured cable from a RCB/RCD unit but need to have confirmation on the wiring layout of the switch. I have been assuming that the live feed to the swithch would go to the first socket and fixed to in L1 (Neutral in the neutral block) and the live outfeed to the filter from COM, would I then bridge the live feed over to the second switch in the unit and repeat the process for lights. Is this correct?
Kevin
Kevin
