I have a 2 gang switch in my kitchen. One switch is a dimmer for spot lights, the other is for flourescent lights.
I removed the cover plate and must have unconnected some of the wires in doing so. I am now unsure which ones need to go where to make it all work again.
Both switches have an L1 an L2 and a 8 (?) connection point.
I have 1 x green/yellow wire that is still connected to earth on the casing.
I have 4 x red wires (2 with red sleeves, 2 without) and a short bridging wire.
One red wire (with sleeve) is connected to 8 of a switch; one other red wire (without sleeve) is connected to L2 of same switch; and one end of bridging wire is connected to the same L2.
I therefore have 1 other red wire with sleeve, one other red wire without sleeve, and the other end of bridging wire to put somewhere.
Any help much appreciated !! Thank you.
