2" gap at the end of bath, should i tile?
1 Nov 2004
hi all
not sure if this belongs in the plumbing or the tiling sub forum so i'll start here.
I'm getting to the end of finishing my bathroom, tiled walls/floor, plubing all in ect and finished fitting my bath today. The bath is 1700mm long and has left a gap of nearly 2" at the end. I was planning on fitting a baton into the gap then using the wall tiles to make a tiny shelf but dont feel this will look very good.
Do any of you have some tips or ideas i could use to fill this void that would be pleasing to the eye?
its not the tap end, but there is a shower fitted at the non tap end (electric shower)
Ideally you could have built the wall out to the correct width before tiling. Now you're really stuck with building a filler piece and tiling it. Or maybe a raised shelf with a slight slope on it.
Hi Rumpleforeskin.
I imagine that building the wall out by nearly 2" was not an option as it isn't for me.
I have just had a bath fitted and am now facing the same problem as you have/had.
Have you now found a way round it or are you still pondering over what to do?
I to was thinking of a small plynth and tiling all round it but like you I am not sure how good it will look.
rodders1949
