Hi
I have a Vailant Ecotec system boiler, 24kw feeding 10 rads in total, plus heating the water cylinder. I live in a typical 1930's 3 bed semi.
Upstairs rads, if on, heat quickly and to full power. In fact out of 4 rads upstairs only two are ever on, we prefer cool bedrooms!
Downstairs rads take up to 2 hours to heat fully, one never gets warmer than "not cold".
I have balanced the system as best as I can via the lock shields, having them open at the minimum setting to allow each rad to heat fully. As a result some lock shields are hardly "on" at all.
I have the boiler set as follows, water temp set to 60 degrees and rad thermostat set to 70, which should be well high enough??
The boiler has been recently serviced and a new pump was fitted. I dont believe the system is clogged with sludge as when I have done any work, water appears clear and I always add inhibitor when refilling.
Ideas?
Crakkers
Ideas?
Crakkers
