- Joined
- 5 Apr 2006
- Messages
- 10
- Reaction score
- 0
- Country
Hello,
We bought a house last year and have had much of the electrics renewed including circuit board / fuse board and a stack of new sockets & light switches installed, old boiler and shower taken out and new ones installed.
1) Recently after about an hour painting the living room, the radio went off and I found that (all) the electrics had tripped out. I flipped the "master" fuse back on and everything was fine for about 10 minutes and then it tripped again. Tried again, a few mins later, same again.
The same thing happened a week later when I was next in decorating, althought the radio was plugged into a different socket. It stayed on initially for about an hour or so and then tripped and would then only stay on for a few minutes.
The boiler, lights, kettle etc have been left powered on for extended periods and the elecs have never tripped out like this before, so it seems that either the radio or the sockets / circuit (downstairs front) is the cause. I've plugged the radio in to various sockets upstairs and didn't experience this issue.
- Before I call out the sparky, could this fault be caused by the radio rather than the electrics? It sounds to my (non-electrician) mind that the radio is taking a while to "overload", but once it does, it trips out quickly and repeatedly thereafter. I can try and get in to test a different radio or other device plugged in in the living room at some point if necessary.
2) We are having a new kitchen installed next. Due to arrive are:
Electrolux double oven (built in)
Electrical connection rating (W): 2800
Current (A): 11.6666666666667
Voltage (V): 240
Electrolux gas hob (built in)
Voltage (V): 230
Plus an extractor and a standard (integrated) dishwasher.
Obviously, each of these are going to require power supply.
I'm told that modern ovens can just be plugged straight into a standard wall socket because the current is less than 13A.
- Although this may be the case, is there a benefit in connecting it to a "proper" cooker point instead?
- Will there need to be 4 sockets (one for each device), or is it standard practice to connect any combination of these devices together?
- Is it worth getting the sparky to install the power supply to try and reduce the kitchen fitters' bill? The sparky is relatively cheap and we can get him to do other things while he's in. But as the kitchen's fitted, the fitters would probably know the best position for the sockets (i.e hidden behind the new units) and in fact would likely make the whole of my second issue moot. Apart from they may inflate the cost.
Any answers / advice is appreciated.
==Clem Bones==
Voltage (V): 240
Voltage (V): 230
==Clem Bones==
