Hi All
I have 1 Myson 800 Kickspace heater fitted in my bungalow kitchen on part copper, part plastic 15mm flow and return pipes which run directly to the boiler through the loft.
Has any body ever fitted 2 of these heaters onto a supply like that?
If so how were they connected to the Flow And Return pipes, in series (outlet of 1st to inlet of 2nd) or in Parallel (Boiler Flow pipe split to both inlets)?
Was the resulting heat output worth it?
Did the fans cycle on & off a lot because the flow temperature fell too low?
If so what was the boiler set point?
Some Info from a real life installation would interesting as I am thinking about doing this.
Cheers
Ian
Cheers
Ian
