Hi
We had a charnwood insert stove with boiler (slx45i) installed a fortnight ago and the plumber (our regular guy) only used one flow and one return. Then the charnwood rep (also a plumber) had to come out cos a handle was broken and he took one look and said its installed wrong and needs 2 flow & returns. So long story short is we got a different plumber to come look at it cos we were annoyed by regular plumber and this one said ' its all well and good using 4 pipes in a new house but 2 should do you' because we already had a back boiler before the stove so its pipes were used. He thinks its not worth the hassle or money to put the two extra ones in. he also said we shouldn't have plastic pipes but I know they're everywhere in our house (following an extension). I've had a good read on the forum re plastic vs copper but is there anything about not using it with a stove? The pipes at the stove boiler and into our hw tank are copper.
I'd really value some other thoughts on this issue. I have read that using the same flow & return for hw and rads can short circuit the boiler-what does this mean. Other than inefficient heat output will it cause damage?
I should say-its being reinstalled no matter what, as the first guy hasn't a straight eye at all and its not level on 3 planes, so now is the time to put in the extra pipes if needed.
