2 port and 3port motorised valves
18 Aug 2004
Sheffield
hello all just trying to get my head around the above subject.it seems a little complicated!! :cry: are 3 ports usde for smaller houses and 2 for larger?whats the 3 tee rule? :eek: i bet it takes a bit of practice getting used to these.i understand the basics; 1 port for hw and the other for ch.wheres the best place to fit them?anybodys opinion would be appreciated if they reply.
There is no rule for port valves.U can use either a three port or two 2 ports
Normally three ports are used when no room stat is evident.
There are two types of three port. Mid position and diverter
i prefer two 2 port valves
The nice thing about 3-port valves is that they don't close - there is always at least one open path - inlet to A, inlet to B or inlet to both A & B. This means that you don't need a bypass for pump overrun whilst the boiler cools.
I do not understand the comment about lack of room stat. You can (and should) use a roomstat to control both 2 and 3 port valves.
thanks for the reply folks.just a couple of questions.in what circumstance would you fit a diverter in preference to a mid position or vice-versa? :eek: also what differenciates the 2,obviously ones got 2 outlets and the other 3.is there certain situations that you would fit one rather than the other.think i've just repeated the first question :oops: getting into a tangle now :rolleyes: thanks up front if anybody can make sense of my messaage :eek: l
22mm 3 port is usually ok for up to 8 normal sized rads above that 2 two ports are better as they are not as restrictive to the flow of water or use a 28mm 3 port..
