2 port zone vales and bypass
16 Jul 2009
Hull
Hey If putting a bypass on a system that has two port valves on it should the bypass be before the 2 port valve so if its off due to reaching temp. on the room stat. It will let water through as the pump will have an over run on it, or if all trv's are off. Is this correct?
