2 pottertons linted with a drayton rb1 relay
2 Nov 2009
London
Customer has a massive house with ch zones and two potterton suprima's, was complaining of no heating/hot water
The boilers are wired with the pump and switched live's in a drayton rb1 relay
one boiler had power but the pump didnt, nor did the second boiler
from what i understand the relay has 2 poles
can sombody explain to me how the relay works in this setup?
I cant fine anything about this relay on the drayton website
it depends on what valves and thermostats you have, there is a wiring diagram on the back of the cover that explains how it works, unfortunately there isint a standard way to wire them, you will have to trace the wires and also check that the relays are switching when power is applied.
I am surprised that in this weather you can walk away and leave the house without heating.
I would say that you should call someone else or just wire one boiler directly.
Tony
Actually i didnt, that is part of the problem, did some rewiring and got live to the pump and other boiler
but now that i have the new relay i cant remember how to wire it in the same way it was before :(
the wiring diagram that came with the relay is really basic
