I've just been stripping the back pump on a Hoover Performa 1100, due to lack of discharge of water, sure enough, out of the pipes came a 5p and some nails, I cleaned out the pump and all seems to be working well, them I noticed a similar pump at the front end of the machine (filter end), this pump had no electrics connected to it or any signs of wires cut off etc, when I disconnected this pump and tried the electric wires from the first pump the 2nd pump worked ok, which brings me round to the questions?
1. Should both pumps be wired up to work on discharge?
2. Can I run both pumps off the same two electric wires, making the necessary adjustments with spade connections etc?
Thanks for any views Jim
Just an update on the 2 pumps: the pump at the front which has no electrics fitted to it goes to the front drain plug, which just unscrews and when you do there is no filter attached it. (nothing with perforations). Now this pump does have a pipe running off it into the centre of the drum. (either to pump back in or take out excess I think?)
The back pump which is connected to electrics does have a sump and the grey plastic drain pipe attached to it.
The sump also branches off to the front pump so the problem I can see is that any water that goes to the front pump, will just
remain there and go stagnent, unless manually drained? Any views?
