Have decided to replace our warm air system for a new wet system and have a quote for two options from an independent heating engineer. Would really appreciate some advice on what is considered the best arrangement. We have a 4 bed detached house with one main bathroom above the boiler. Other water outlets are a cloakroom the other side of the wall from the boiler, a sink in the same room as the boiler (utility room) and a sink in the kitchen which would be a run of about 4-5 metres. We need 11 radiators.
Option 1: Vailant ecoTEC 832. Honeywell DT92e or CM927 programmable thermostat
Option 2: Vailant ecoTEC 630 with Main 170L unvented hot water cylinder. Honeywell DT92e or CM927 programmable thermostat
The engineer has suggested that Option 1 would be the best because all runs to the water outlets are fairly short. We currently have an electric shower in the bathroom and use little additional hot water. The engineer said that we would have a better shower if we ran it off the the boiler but then we would have no hot water backup if the boiler failed. It would be good to lose the electric shower though.
Could I ask..are these vailant boilers good, would the combi be ok or do you recommend having the cylinder. I just want the simplest, most reliable setup but am unsure of the best option. Another well know gas company had a look and the two engineers started arguing over the best option, hence I have turned to an independent engineer who is an advanced vailant installer so that I can get the extra guarantee on the boiler.
Sorry for the waffle but really appreciate your advice.
