2 radiators in loft
14 Sep 2010
Rochdale
I have the flow and return pipes sticking up in the loft and want to pipe up 2 radiators.
Should I just put a T ontop of each and run from there to each radiator or is it not so simple?
T on each leg to feed either end of the rad is straightforward enough. Getting the water that high sometimes is the issue, is it a sealed system?
Should be fine then, pump would be man enough I would think. Will need to balance system possibly to ensure sufficient flow gets up there.
