I had a new central heating and hot water system installed a couple of years ago, and 2 radiators in my extension have stopped working this winter.
Any ideas?
Thanks a lot for your help.
(Note that I added the Magnaclean at a later date, and I know that it's missing the return flow from this section, I just had no room to put it anywhere else)
- The radiators are on the downstairs zone, but are on their own section (see picture)
- The rest of the radiators on the downstairs zone work fine
- As pictured, the flow to the broken radiators feels hot until just above the isolation valve. The pipes to the radiator are therefore completely cold.
- Boiler is Vaillant Eco Tec Plus 637
- Cold system pressure is 1 bar
- Making sure the lockshield valves are open
- Bleeding the air out
- Draining and refilling
- Removing the TRV heads to check for sticking pin
- Balancing the system
Any ideas?
