Having a problem on my mothers radiators at the moment.
She is running Worcester 24CDI RSF combi boiler.
Problem is started to lose heat in only two radiators, one on ground floor one on first, upstairs one is directly above the downstairs radiator. Heat can be felt on flow in pipe, only a little heat can be felt at the top of radiator & nothing on the return pipe, stone cold. all the other radiators are red hot maybe even too hot.
Don't know it this helps but the pressure on boiler keeps dropping down to almost zero when it is normally set at 1.5 bar. The system pipes are all plastic.
Both radiators have been replaced as has a plastic manifold she tells me.
Would appreciate any help as she is losing faith in the plumber she is using.
Chris
Chris
