2 switch wiring
11 Sep 2006
Yorkshire
Ive recently moved into a new house and living room switch isnt working.
it controls both the living room and dining room lights (two switches, one for each) the dinning room also has a seperate switch actually in the dinning room, this isnt working at the moment either.
The switch in the living room is a newish one, it has modules behind each switch that are labeled:
L1 COM L2...
so switch 1 has L1 COM L2
and switch 2 has L1 COM L2
none of the wires were connected at all when i removed the switch from the wall... there are four wires
two red, one blue and one green/yellow, there was also a small wire hanging out of one of the COMs so Im presuming this is/was used to loop to one of the other connections.
any ideas what should go where
Cheers
that sounds a mighty odd combination of colors (and too few wires to support the switching setup you say is meant to be there), are you sure there isn't a black wire and/or a yellow wire that you've missed?
also there should be an earth from each cable (assuming it is cables and not singles in conduit).
Not sure if you've managed to fix it by now but I was reading your problem and thought just in case here you go...
switch 1:
L1 = the 2 red cables
L2 = Blue (plus a black if present!)
Com= Yellow
switch 2:
L1 = red
L2 = Blue
Com= Yellow
This is a conventional 2 way lighting circuit where switch 1 used to be a single way switch.
switch 1:
Com= Yellow
switch 2:
L1 = red
L2 = Blue
Com= Yellow
switch 1 is a 2-gang affair. byebye your theory ;)
And if the black weren't present, it still wouldn't work. So why say "if present"? He gives no indication ther is a black there, so why assume there is?
