2 way concealed shower fitting
4 Oct 2012
Cheshire
Hi there, hopefully somebody can help, just a quick question about a concealed 2 way shower Im fitting.
I'm fine with the fixed arm, screwing into a female fitting with backplate, but does the same apply to the other fitting which the hose attaches to? The reason for my question is that that fitting is plastic, so i am concerned that the plastic will crack as it is tightened into the brass fitting.
Is this the right thing to do or should another type of fitting be used i.e. a tap connector?
