2 way dimmer - odd markings
20 Jan 2006
Buckinghamshire
Have purchased 2 way dimmer from H*mebase - very smart 'electronic' dimmer but has odd markings on terminals - at present I have red on L1, blue on L2 and yellow on L3. New switch has L, Sw, and a 'wave' symbol with diagonal arrow thru it. Instructions state that Live/Common (brown or red) should connect to L, blue or black (with brown or red taping) connects to Sw from L1 of second switch, and the 'wave' connects to 'lamps' via blue or black (with brown or red taping). I am just a bit confused!!
BTW if any use the item is labelled 'CASSA Double Dimmer 250watt 2way' - I plan to operate two x two way dimmers (on different rooms)
Hi, Sneakypete,
I've just bought a two way dimmer switch in France and it has the same markings, except with two terminals marked "L". There were no wiring instructions!!!
I've tried every combination of wiring but cannot get it to work two way. The other original two way switch cuts the power to the light, but the new dimmer won't turn it back on again.
Sorry I can't be more helpful!
Any advice would be welcome,
Dave H
