Hello, just installed a new 2 way dimmer switch and it turns on and off but does not dim at all. It is controlling just a standard 40w bulb so shouldn't be anything to do with that? Any ideas anyone?
Not sure that this is a DIY disaster per se. Might be better posted in the sparks forum. I've not really done anything with dimmers, but afaik, I can't think of a way to wire it up so that it work switch but not dim. Maybe a faulty dimmer?
As a first step, please tell us what colour wires you have on which terminals on the dimmer, and what terminals they were connected to on the old switch.
