hope someone here will have an idea.
doing a spot of decorating (joy) and just changed a double lightswitch
old switch labeled Top L1, L3, L2 with a red wire in L1+2, and a black with a red collar in L3
Bottom L3,L2,L1 with red to L1 + L2
New Switch Top Common, L1, L2
bottom L2, L1, Common
i put all the L1 and L2 back in the correct places, and the L3 into the top common, now 1 switch turns one light off, and the other on, the other switch does nothing
changing the L3 (black with red collar) to the bottom common gives nothing.
landing light operated by this switch and another at top ot the stairs. this switch also operates a hall light. all worked with the old switch, just noticed it says 'double' not '2 way' on the new fitting.
Advice welcome (so long as it doesn't involve putting old switch back on, or calling a sparky).
