Hi all - new here
I have a question about adding a 2 way switch to some existing wiring that goes from my landing to my loft.
This is where I started:
On the landing - 1 gang, 2 way switch that controls the landing light. The other switch for this is at the bottom of the stairs.
Wiring for the landing switch: Common - Red with red sleeve. L1 - Black + Yellow with Red sleeve. L2 - Red + Blue with Red sleeve.
In the loft - - 1 gang, 1 way switch. I believe power is supplied from the landing light ceiling rose. (I think my Dad done this years ago) Common - Red. 1-way - Black.
So far this all works fine.
Next I have bought some 3 core cable (black, brown, grey + earth)
I have changed the switch on the landing to a 2 gang switch.
The wires for the landing light (switch 1) are all back in their original places. I have double checked this as I done a diagram before removing them.
Next I am taking the 3 core cable from switch 2 to the loft. Switch 2 on the landing is wired as follows:
Common - Brown. L1 - Black (tagged with brown). L2 - Grey
I have also changed the switch in the loft to a 2 gang switch.
One of these will obviously be the secondary switch from the landing switch.
The second switch will eventually control additional lighting in the loft.
So, the new 2 gang switch in the loft -
Loft Switch 1
As on the landing:
Now the existing cable that was already there for the switch (as I want to control this light from up in the loft too) as mentioned earlier is a red cable and a black cable - power supplied from the landing light ceiling rose.
I have wired this as follows:
Common - Red. L2 - Black
PROBLEM: Loft light is permanently on, unaffected by any switching
Landing light still works as it should.
What have I done wrong??
Thanks in advance
Loft Switch 1
As on the landing:
Thanks in advance
