Have a double light socket in my downstairs hallway that controls my hallway lighting, and the lights in the landing on the 1st floor. These are working fine (recently re-hooked up by an electrician after the boxes were changed for new ones)
The problem is, I can only get the landing light on the 1st floor to turn on after I physically switch it on at the landing switch (at which point both sockets on the ground and 1st floor correctly control the landing light)
If I try and switch the landing lights on from downstairs, the light will not turn on, yet once I switch on from the 1st floor both switches (ground floor and 1st floor) control the landing light correctly. This is a new problem since I replaced the landing switch myself (e.g. worked fine when the electrician did the ground floor lighting)
The landing socket has 2 x live (red) and 1 x black wires, and I've tried every configuration I can think of. The socket is from B&Q and is an MK2 (2 x live and 2 x neutral inputs)
Any help greatfully received - pics available if necessary.
