Hi all
Need some help on 2 way switching.
The house is a terraced house which has a through lounge. There are 2 lights and 3 switches.
- first switch is as you walk in, 1 gang to control the front light only
- second switch mid-way along the length, 2 gang switch to control front and back light
- third, opposite wall of seconds switch, 2 gang to control back light and upstairs landing light.
Now the problem is the 2 way switching for the 2 downstairs lights dont work. Looking at the wiring, there is a 3core + earth from the 1st switch to the 2nd switch. Then only a twin + earth from the 2nd to the 3rd. This all worked a while back, but electrics tripped one day and never worked again.
I have done a continuity test on the 3core + earth and it is dead on one of the cores, but its not shorted to any of the other cores or earth.
I guess this is where the problem has started from.
Any ideas on what could have caused it and if there is anyway I could get this to work with Twin + earth?? The whole lounge has been redecorated so I dont want to re-wire it
Thanks in advance
Thanks in advance
