Sorry yet another 2 way lighting problem. This seems really strange to me.
Downstairs 3 gang switch controlling hall (1 way), landing (2 way) and outside light (1 way). Upstairs 2 gang 2 way switch controlling landing (2 way) and second floor landing (2 way).
Everything works perfectly except the 2 way control of the landing light.
This worked perfectly until today when I replaced the landing 2 gang 2 way switch. So before today I could control the landing lights from the hall and the landing as expected.
Having read around the subject and consulted the wiki, the wiring was as I expected.
I will only refer to the landing light connections. Downstairs in the hall is a 3 core and earth with yellow to com, red to L1 and blue to L2.
Upstairs on landing switch was yellow to com, red to L1 and blue to L2. Additionally a twin red and earth with one red to L1 and one red to L2.
I emphasise that all was working fine at this point. I then replaced the plastic switch with a plastic MK one, and since the cables had give I transferred the connections one by one.
I now have in the new landing switch yellow to com, red to L1 and blue to L2 from the "connecting cable" and one red each from the lamp cable into L1 and L2. I kept the pairs of wires going into L1 and L2 together and transferred each separately.
So in theory I have exactly the same wiring as before I replaced the switch. However I have clearly done something wrong because now although the landing switch controls the landing light, it only does so when the hall switch is in a certain position. If I flick the hall switch then the landing light goes out and the landing switch has no effect.
I have checked the connections at least 10 times. I have also not altered the downstairs hall switch at all, and I have rechecked the connections - definitely yellow com, red L1, blue L2.
Since it was working normally before I changed the switch, and now it works as I describe obviously I have changed something without realising. But I am at a complete loss as to what.
