2 whirlpool washer faults
17 Mar 2011
Hi guys,i have 2 whirlpool washing machines and they're both giving trouble
1st model is AWOD 6727- it originally wouldn't start so i put it into test mode and it stopped on error F13 which seems to be door interlock.I bypassed this for test purposes and it's now displaying F26 and still won't start . I then replaced the pressure switch and blew out the pipe but it's still showing F26
2nd model is AWO 10761-it won't start either and displays error F11. I checked the motor brushes and also checked the motor readings at the controller end and they seem normal.
i'm not certain if i am interpreting the error codes correctly ?
i assume the faults are likely with the circuit boards in both cases but would appreciate any advice:)thanks
i figured out the problem with the AWO 10761-it's the controller board
i stuck it in the oven and it's back working temporarily until i get it replaced
still looking for assistance with F26 error -nearly all the lights on the dashboard are also iluminated
