2 wire rectifier for Briggs and Stratton engine
11 Jan 2004
Hello,
I have a two wire Briggs and Stratton rectifier as shown in photo that converts AC power from the alternator to dc to charge battery while the engine is running.
The 11.5 hp Briggs and Stratton engine has one wire coming from the alternator. Can someone tell me please which wire ( yellow or red) the alternator wire connects to and which one connects to the battery to keep it charged. Thanks
Red is the normal colour for positive for DC, so red to battery. Yellow is commonly used for AC, so yellow to alternator.
Thanks for your response, appreciated. I know that the DC cable can be connected to key switch ( R for regulator) to charge battery once it is turned on and while engine is running but can it be connected straight to positive terminal on battery instead ?
Also does the rectifier normally have a limit on the DC current coming out of it (around 12v) and does it only allow current one way? Thanks in advance.
I guess you have one black wire coming out of the stator? Harry is bang on with his response and the black changes to yellow.
Personally I'd go for an ignition switch system as I have had on occasion a battery leak back through the rectifier / regulator but whether that was due to a fault I don't know.....the ignition switch cuts everything dead I think.
That wee device of yours has two functions - it converts AC to DC and also limits the voltage to around 14v when running fast. The engine doesn't produce enough current for anything to get hurt and yes, it only allows current one way (theoretically!)
John :)
I'm not convinced it will actually limit the voltage, but if it does, to do that it would need to be firmly bolted to the chassis/ negative.
I have had bikes where the alternator output is just rectified and connected across the battery, without any regulation at all. I've had bikes which had 3-phase alternators, where the output was simply limited by shorting the surplus voltage to chassis/negative.
If it helps, have a look at the attached. You might have to pull the flywheel off though, to see what sort of windings you have in the stator.
  • alternator_id.pdf
I also have a much larger file (13 Meg) with wiring diagrams for just about every alternator they ever did. However, I just get an error message when I try to upload it. Is there a limit on the size of file I can upload on here? (It's a PDF). Failing that, PM me an e-mail address and I can send it to you.
